Forums >> Revit Building >> Technical Support >> Wall Opening
Mon, Jun 17, 2013 at 8:36:52 AM | Wall Opening
franchevich
The wall opening tool isn't working on straight walls just on curb walls,
Any idea?
Mon, Jun 17, 2013 at 8:50:48 AM | Wall Opening
If you want help here, you always need to give more information.  Version - updates?
We use the wall opening tool in all versions (except not 2014) and have not had problems.  That would indicate that you are probably doing something incorrectly.... like setting your opening to a height above your wall or out of view.
Mon, Jun 17, 2013 at 8:58:32 AM | Wall Opening
franchevich
Good point, I'm in version 2012 and I do have to walls side by side, one is straight and other curb same settings boths,
and the opening tools does not work on the straight and works on the curb wall,
thanks,
Mon, Jun 17, 2013 at 9:03:17 AM | Wall Opening
"...curb walls..."   Do you mean curved walls?
Are you placing your opening from a plan view?  If not, then you should be.
Mon, Jun 17, 2013 at 10:59:30 AM | Wall Opening
franchevich
I got this resolved,
Thanks for the help!
Mon, Jun 17, 2013 at 11:07:39 AM | Wall Opening
This is a share site and the users learn from posters sharing their questions and solutions.  Please post what the problem was and the solution.
Mon, Jul 8, 2013 at 4:00:11 PM | Wall Opening
franchevich
the solution for this matter it was simple just go to Home tab > Opening and Wall opening,
Thanks,
Control the depth of a wall opening?
Wed, Jan 19, 2011 at 2:09:23 PM
Wall Openings
Mon, Mar 9, 2009 at 2:40:22 PM
Why does the wall opening cut only go up 2/3 the height of the wall?
Sun, Feb 18, 2007 at 8:53:25 AM
Wall Opening
Tue, Jul 10, 2007 at 10:24:02 PM
Windows/opening/curtain system on inclined wall
Tue, Apr 21, 2009 at 5:16:45 AM
Page generation time: 0.7866
