2 Users Online (0 Members):
Forums >> Revit Building >> Technical Support >> Issues with Light Source in Revit 2013
3 Posts No Rating |
Hello, I'm trying to create a wall hosted lighting fixture but I'm having issues with the light source direction. I'm trying to set the light to come from the wall (left/right direction), but it's by default paralel to the reference level; as seen on images 1 and 2. Now, if I rotate the light source to fit my needs it won't appear in renderings. I'm wondering if there's any way I can do this. I'm not sure if I'm doing something wrong or maybe trying to achieve something that's just not possible.
Thank you.
You mean like this?
Go to anjother view and rotate there.
3 Posts No Rating |
Like this, actually, but when I rotate it to this position it wont appear in renderings anymore.
Your light source is a line. That line must be in front of the wall - not in it! Move it out to where your light bulb would be.
3 Posts No Rating |
It's actually a rectangle. I've tried creating an unhosted lighting fixture family and rener it, it renders correctly, the moment I try to rotate it it stop appearing in the renderings. I don't know if I'm soing something really wrong or just rationalizing it the wrong way.
I have never used that light source. When did they add that?
I checked it out and that family seems to have a bug. Report it to AutoDESK.
I suggest you use a face based template.
Light Source in Revit - the dead horse |
Thu, May 6, 2021 at 4:34:17 PM
13
Light source inside the light fixture |
Fri, Feb 22, 2013 at 7:24:32 AM
Light Source |
Thu, Feb 19, 2009 at 8:01:01 AM
Downlight with hidden light source |
Sat, Nov 23, 2013 at 8:19:33 AM
Light Source not rendering. |
Fri, Mar 17, 2017 at 11:09:15 AM
