30 Users Online (28 Members):
Forums >> Revit Building >> Technical Support >> Wall Base Profile Detail Level in Wall
105 Posts No Rating |
I made a profile for some wall base and used the "Visablity /Graph Overrides - Edit" to set all the lines of that profile to show only in "Fine"
I edited that walls type and added a sweep of the base to wall - it looks good.
The problem is that the base shows in plan and elevation at all detail levels. How do I get that base profile sweep to show only at Fine Detail Level?
All sweeps defined in the wall type always show in plan. We have complained about this for a long time. Only added sweeps can be turned on/off.
Well that stinks. Thanks.
Overhead wall and Level 3 are not aligned |
Thu, Mar 17, 2016 at 10:17:42 AM
Wall detail in plan vs section |
Mon, Jan 12, 2009 at 10:32:23 AM
Adding wall base |
Thu, Aug 31, 2006 at 10:44:34 AM
Repeatig wall sweep vs. repeating detail - wall attached [ 1 2 ] |
Sun, Dec 7, 2008 at 3:51:44 PM
19
Wall Base Offset... one works, one doesn't. Why? |
Wed, Jun 10, 2015 at 2:53:52 PM
