7 Users Online (5 Members):
Forums >> Revit Building >> Technical Support >> RAIL JOINT
43 Posts No Rating |
Greeting,
Is there a way to joint the attachment rail...?
Draw that as 1 rail instead of 2
You want a vertical there? If not, then edit your upper rail so the return is at the other elevation.
Yes, we made a split for the railing, at the riser then
On the option bar we put the slop flat, then play
With height correction, it work , and we got
A contŘ rail
Thanks for u
rail termination |
Tue, Apr 8, 2014 at 10:18:59 AM
Set baluster on Bottom Rail |
Thu, Mar 29, 2012 at 8:59:47 AM
Top rail offset |
Wed, Jun 21, 2017 at 11:14:51 AM
stair railing baluster properties not consistant with deck rail |
Wed, Sep 3, 2008 at 11:08:32 AM
Creating an expansion joint family |
Sat, May 2, 2009 at 10:57:03 AM
