Forums >> Community >> Newbies >> Unable to have same elevation view names
Thu, May 9, 2013 at 11:32:37 AM | Unable to have same elevation view names
Chunkymonkey
5 Stars: 3 Votes
Greetings,
I have an office fit out job and am setting up seperate sheets for each area that needs detailing, ie; Staff Kitchen, WCs, Meeting Rooms etc.
Now for each room there will be 4 elevations and I'd like to be able to maintain a sensible naming discipline, ie; Elevation A/B/C/D etc. However when I try to rename a new set of elevations for a different room Revit (Arch 2013 ) tells me that the view name is "already in use and to choose a unique name". I can rename the name of each elevation view by adding the room name to make each view unique, but this makes the title long and very repetitive especially when you have 4 elevations on one sheet, the client does not need to see 'Kitchen elevation 1.....Kitchen elevation 2 etc when he is already looking at the kitchen drawing sheet. I have played around with adding a project parameter and organising my project browser (as attached image).
Any ideas on how I can have 'Kitchen Elevations A,B,C,D' and 'Staff WCs Elevations A,B,C,D' would be appreciated.
Many thanks,
CM.
Thu, May 9, 2013 at 11:53:14 AM | Unable to have same elevation view names
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You cant have the same VIEW name in your project browser however if you click on the view and look in your properties you will see a Title On Sheet section and you can name your view whatever you want on the sheet.
Thu, May 9, 2013 at 12:04:53 PM | Unable to have same elevation view names
Chunkymonkey
5 Stars: 3 Votes
I see, thank you very much for the tip and for the quick response.
CM.
Mon, Jul 21, 2025 at 7:58:05 PM | Unable to have same elevation view names
konradsten
Hi,
Yeah, section marks appearing in every view can be really annoying, especially when they're not relevant and just clutter things up. Revit shows section markers by default in all views where the section line intersects the view range, which is why they pop up everywhere. Common workarounds include adjusting the view scale (since markers might hide at certain scales) or using visibility/graphics overrides to filter them out based on type or parameters.
If you're tired of manually hiding them or setting up filters each time, I created a free add-in called Sections Hider for the Revit community. It makes it quick to hide unwanted section markers in specific views without generating new filters or toggling them on/off for every section – simplifies the process a lot. It's compatible with Revit 2025 and later, lightweight, and no strings attached; just wanted to give back something useful.
Check it out here: https://apps.autodesk.com/RVT/en/Detail/Index?id=9178681668701145560&appLang=en&os=Win64
Let me know if that helps or if you have more details on your setup!
view names in building sections are missing
Wed, Apr 2, 2008 at 6:19:24 AM
Hiding View Name in Elevation View Tags
Fri, Jan 21, 2011 at 6:47:39 PM
Unable to duplicate a view
Tue, Sep 13, 2011 at 6:44:21 PM
Project Browser organization . . .Sheet - detail number?
Mon, Aug 29, 2011 at 9:53:14 AM
Interior Elevation Tag
Wed, Dec 19, 2012 at 2:25:25 PM
Page generation time: 2.5261
