8 Users Online (6 Members):
Forums >> Revit Structure >> Technical Support >> Existing floor with a new stair opening... need help with phasing
38 Posts No Rating |
Hello,
I have an existing building modeled with an existing floor slab that has existing openings shown. I used the Vertical opening tool to put those in. However, now I need to cut a new hole for an escalator. I set up my phases of Existing, Demo and New Construction. Now, I need to cut a new hole, so where do I do this? On the demo plan or new construction plan? Any plan I seem to cut it on, either demo or new, the properties shows it as existing. Help?
I typically don't use shafts. In existing phase, I would add a sketch of the holw in the floor slab. Then I would add a floor slab that fits the hole & join the two. Now in new phase, demo the hole.
Thanks for responding. I followed your instructions, and it worked, however it did not show the "new" hole as new construction.. the properties were still existing.
So, I have decided to just add the holes and then go over with the linework tool to make them display like I want them to.
Thanks
Phasing / Floor Infill |
Tue, Mar 6, 2012 at 11:15:01 AM
new opening in an existing floor |
Tue, May 15, 2007 at 3:49:38 PM
11
Phasing and penetrations |
Tue, Jul 28, 2009 at 10:35:15 AM
Stair questions... Revit 2010 |
Wed, Jul 13, 2011 at 12:23:39 PM
demo opening in existing wall |
Tue, Feb 21, 2012 at 2:38:17 PM
