Forums >> Revit Building >> Technical Support >> PDMODE COMMAND
43 Posts No Rating |
Greeting to all,
want to ask if there a command in REVIT, similar to PDMODE command in Atutocad ?
No
So is there a way to make survey point. Appearing in revit?
I never had any problem with that, in CAD I change the Pdmode like I want then import to Revit, what version are we talking about?
I DID THAT, BUT STILL NOT APPEARING, USING CAD 2010, REVIT 2012
Greeting,
attachment site plan with blue servey..points...once it imported to revit it dos'nt appear..
can any one help with...?
In that DWG file all of those points, lines, polylines, arcs and so on are at Z=0, you don't have elevations with Z=0.
Yes u r right... But I can't. See my points on revit
Like this?
Think , I got it... Thanks for you
REPEAT COMMAND? |
Fri, Oct 31, 2008 at 10:01:42 AM
Where is render command in 2010 |
Thu, Feb 18, 2010 at 9:37:00 AM
Copy during Align command? |
Wed, Sep 5, 2007 at 5:05:22 PM
Command bar multiplies during commands |
Fri, Aug 19, 2011 at 1:21:57 PM
Fillet Command |
Tue, Jul 17, 2007 at 10:47:07 AM
