Forums >> Revit Structure >> Technical Support >> I can not select some elements in a file
Wed, Apr 3, 2013 at 4:35:39 PM | I can not select some elements in a file
crosado
I was given a file from a client. I open the file and detach from central. i detached and preserved worksets. i can select some elements in the project but there are others i can't select (ie gridlines or some model elements). what am i doing wrong?
Wed, Apr 10, 2013 at 5:28:15 PM | I can not select some elements in a file
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Unless you plan on turning the file you have back into a central file you should NOT preserve worksets. I suspect this is your problem.
Discard the worksets when you dettach. As is, you will need to make all the worksets editable to edit the content of the file..
Dettaching a central file, leaving worksets enabled and not converting it back to a central file will cause you problems.
The whole reason you have the option to preserve worksets is to turn it back into a new central file.
select elements on current level only - revit 2014
Tue, Jul 23, 2013 at 7:52:33 AM
Select only required elements
Thu, Jul 17, 2008 at 2:10:18 PM
2015: selecting elements in link
Tue, Nov 18, 2014 at 1:17:26 PM
12
Given a central model: unable to select some elements
Tue, Apr 16, 2013 at 12:55:06 PM
Can't select elements like in 2011
Wed, Jun 22, 2011 at 8:19:09 AM
Page generation time: 1.9086
