Forums >> Revit Building >> Technical Support >> Associated level not correct
Mon, Mar 4, 2013 at 7:49:14 PM | Associated level not correct
BlueFairy
I have a second floor plan that has its properties associated with the roof plan as indicated in the Properties bar. Consequently every component I place in the plan such as a chair is placed ant the roof level.  I dont know how to change the associated level to be second floor since the menu is greyed out.  I dont know how this happened.  There must be a way to correct this.
Thanx for anyone who can answer any of my complicated questions. ah!
Mon, Mar 4, 2013 at 9:04:07 PM | Associated level not correct
CDWdavid
5 Stars: 5 Votes
Hi BlueFairy,
You might accidentally renamed the name of that level but didn't check "Yes" for pop-up window "Would you like to rename cooresponding level and view".
Go to plan view, select the level you have problem in the "Project Browser", right click, you will see a "pop up" window with "Rename" option; select and rename that level and check "Yes" when "Would you like to rename cooresponding level and view" showed. Hope that can fix your problem.
Tue, Mar 5, 2013 at 10:02:32 AM | Associated level not correct
BlueFairy
Well, ...I had to delete the floor plan in the project browser.  I went under the views tab and found the "Plan Views" and selected the floor plan option.  I found the 2nd Floor which had the association problem.    I highlighted it and clicked the OK button..    Now it has the correct association.  Cross my fingers and hope  nothing bad happened.
Thanx for all your help.
How i can change the level with out move the building
Sat, Apr 29, 2017 at 8:03:05 AM
Revit 2011 - Curtain Wall doors on Schedule for correct level
Thu, Jun 7, 2012 at 1:22:49 AM
floor plan is not shown correct.. some parts are shown as below level
Wed, Nov 10, 2010 at 3:18:15 PM
topography not being generated at the correct level
Thu, Oct 12, 2017 at 8:01:15 AM
Problem with level display
Tue, Apr 6, 2010 at 12:58:24 PM
Page generation time: 1.5312
