Forums >> Revit Building >> Technical Support >> drafting view
Thu, Jan 26, 2006 at 2:42:02 AM | drafting view
bobbo
Is there anyway to copy a section view to a drafting view so I can have a play and tweak certain elements? I get tha no can do symbol when I try to paste a section view Cheers
Sat, Jan 28, 2006 at 5:55:11 PM | RE: drafting view
eldados
eldados Avatar
4.5 Stars: 8 Votes
just edit your section view with drafting lines and regions (should you need). The section is part of the model (3D) you are asking to converte it to 2D...
Integrator
KarelCAD
Flagging new Drafting Views - How to reference a drafting view detail?
Wed, Aug 1, 2007 at 10:26:29 AM
Would like to copy a drafting view from one project to another. [ 1 2 ]
Mon, Jan 4, 2016 at 6:07:17 PM
17
Rebars - Stirrups Tie in Drafting View
Wed, Aug 1, 2012 at 9:47:36 AM
Trouble copying detail items from Section View to Drafting View
Mon, Aug 19, 2013 at 1:08:05 PM
Using a callout on a drafting view
Fri, May 16, 2008 at 10:39:58 AM
Page generation time: 1.4930
