Forums >> General Discussion >> Revit Project Management >> Question about Sheets
Sat, Feb 16, 2013 at 12:43:12 PM | Question about Sheets
revituser24
revituser24 Avatar
3 Stars: 1 Votes
I need to place  house plans on sheets.  I am using a template.  How do I do that? How do I save it?
How do I place  multiple views(viewports) on a single sheet?
The help menu is not clear.
Edited on: Sat, Feb 16, 2013 at 12:45:11 PM
Sun, Feb 17, 2013 at 5:42:33 AM | Question about Sheets
4 Stars: 205 Votes
In your sheet plan just "drag-and-drop" the views you want from the "Project browser"
Sun, Feb 17, 2013 at 2:05:38 PM | Question about Sheets
revituser24
revituser24 Avatar
3 Stars: 1 Votes
Thanks Typhoon.
My teacher might want the class to create our own sheets and schedules in the coming weeks. Right now the class is using revit's built in template.  I am wondering why would on the job people want to create their own sheets and schedules when it is easier to use revits pre-made templates?
My assignment is coming up soon, so when it does come, I'll start a new thread on how to create my own sheets and schedules.
If you know of any short cuts and tips go ahead and let me know, as far as sheets and schedules goes.
Mon, Feb 18, 2013 at 7:22:33 AM | Question about Sheets
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"I am wondering why would on the job people want to create their own sheets and schedules when it is easier to use revits pre-made templates?"
Firms generally have their own set of standards that their office conforms to.  On office will do things differently, have their sheets, title blocks, texts, dimensions etc different than another office to separate themselves from others.  Revits pre-made template is a beginning or a starting point for users, firms want to customise their template for their specific wants and needs.
Sat, Feb 23, 2013 at 12:18:34 PM | Question about Sheets
revituser24
revituser24 Avatar
3 Stars: 1 Votes
When I choose to print 1/2"=1'-0", this scale(First Floor) appears outside of the revit template border. How do I move it so that it is inside the border?
The 1st floor scale and the drawing appear out of place together at 1/2" scale. why? how do I correct it at that scale?
Edited on: Sat, Feb 23, 2013 at 12:28:07 PM
Edited on: Sat, Feb 23, 2013 at 12:29:41 PM
Wed, Feb 27, 2013 at 3:14:03 PM | Question about Sheets
revituser24
revituser24 Avatar
3 Stars: 1 Votes
Is the view scale the same thing as the print scale?  I have a view scale of 1/4"=1'-0", but it is not printing at 1/4"=1'-0". Why?
Wed, Feb 27, 2013 at 3:31:08 PM | Question about Sheets
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Your view scale is set up in your view, for example 1/2"=1'-0" then you go to a SHEET (say A101) and drag your view from the project browser onto your sheet.  You need to set up your printer properties so that its set to zoom to 100% if you are trying to print full scale drawings.  You said this is for your teacher, isn't he showing you any of this?
Wed, Feb 27, 2013 at 3:49:19 PM | Question about Sheets
revituser24
revituser24 Avatar
3 Stars: 1 Votes
thanks teafoe5. I got the right scale to print, but now the border does not print. Why?
I centered the page and the border still does not appear. Why?
Edited on: Wed, Feb 27, 2013 at 3:51:42 PM
Wed, Feb 27, 2013 at 3:55:56 PM | Question about Sheets
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Attach a screen shot of your Sheet.  Are you plotting to the correct paper size?
Wed, Feb 27, 2013 at 3:56:54 PM | Question about Sheets
What linework is your border?  Revit sees the sheet based on an invisible line in the sheet family.  The printed border is a normal inetype inside of that invisible line sheet limit.
Wed, Feb 27, 2013 at 4:26:41 PM | Question about Sheets
#11
revituser24
revituser24 Avatar
3 Stars: 1 Votes
Thanks guys.  I went to print setup and did the following:
1.- offset from center x=0.0, y=0.0  (user defined)
2.- zoom 100%
I got the right scale to print and the border to print as well. Thanks guys.
Drawing Sheets
Sat, Sep 8, 2007 at 11:45:15 PM
Multiple sheets with the same name.
Fri, Oct 18, 2013 at 7:19:00 AM
Work around for sheets and new project
Thu, Jul 23, 2015 at 3:59:16 PM
Schedules/Legends on Placeholder sheets
Fri, Dec 6, 2013 at 5:22:48 AM
Reordering Sheets
Thu, Nov 1, 2018 at 2:09:29 PM
Page generation time: 0.3213
