58 Users Online (56 Members):
Forums >> Revit Building >> Technical Support >> Hotfix - Autodesk Revit 2013 - Server and Part Family
This hotfix addresses issues in two main areas:
Part Family:
- Prevents data loss during upgrade of families containing specific material parameters.
- Improves stability and memory usage within graphics display.
- Improves vector print output of transparent elements and masking regions.
- Prevents accidental data loss during cancellation of the in-place family editor.
Revit Server:
- Revit would occasionally report that an operation could not be completed when attempting a worksharing operation after a period of inactivity, if Riverbed devices were used in conjunction with Revit Server. A subsequent retry of the operation would then succeed. When this hotfix is applied to Revit, this behavior is eliminated. No changes to Revit Server are required.
Make sure that Update Release 2 has been applied prior to adding the hotfix. Verify that the build number of Revit 2013 is 20121003_2115.
DOWNLOAD FROM AUTODESK SITE: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21147820&linkID=9273944&CMP=OTC-RSSSUP01
Edited on: Sun, Jan 27, 2013 at 6:32:33 AM
TY just curious how your office addresses these updates. Do you go around to everyones work station and update as soon as the fix becomes available? I have the update on my computer, I know everyone should update but is there any repercussions of me updating and the rest of the office not?
"Do you go around to everyones work station and update as soon as the fix becomes available? " - YES, my IT team do that...
"... but is there any repercussions of me updating and the rest of the office not?" - In this case (hotfix) I don't think so but....
Revit Fatal Error |
Tue, Jan 12, 2010 at 10:35:50 AM
Revit Server Vs. Autodesk Buzzsaw |
Fri, Oct 8, 2010 at 1:14:31 PM
Server for Worksets |
Fri, Aug 5, 2022 at 3:13:03 AM
Family and Template Install Location on Server |
Fri, Dec 11, 2009 at 3:48:35 PM
Revit Server |
Tue, Jul 24, 2012 at 8:00:13 AM
