Forums >> Revit Building >> Technical Support >> Adaptive Component/Pattern Base Panel
Wed, Dec 5, 2012 at 5:17:31 PM | Adaptive Component/Pattern Base Panel
Thread Post Kudo! #1
AndyK81
Hi all, hope this is in the right section...
I've built a parametric shell type structure using a conceptual metric mass as the starting basis, which is basically an arched structure in form.. I apply a grid to the surface (switch on nodes) add my adaptive beams to it. then created a curtain wall panel pattern based element for it. To the pattern I have hosted an adaptive component, with the ability to altered is shape to the grid. However when i load it to the grid it doesn't follow the grid pattern, any idea's. In the image below I have highlighted the panel in question (there will be several of these panels if i get it to work properly) basically these panels should follow the grid & are adaptive components, with a parameter to alter the angle, as in an mechanical skin that opens & close for ventilation & light..... https://dl.dropbox.com/u/15480632/Capture.JPG I can dropbox the complete file if its easier to try see what i am doing...
Pattern Based Panel - Curved Issue v2015
Tue, Feb 2, 2016 at 7:09:07 PM
Area of Generic 4 Point Adaptive Panel Family
Wed, Jan 20, 2016 at 10:31:29 AM
Adaptive component documentation
Wed, May 11, 2011 at 3:51:41 AM
Show user created dimensions within Adaptive Component in Sheets (2016)
Fri, Jul 1, 2016 at 1:55:50 PM
Adaptive rectangular pattern with bubbly holes
Thu, Sep 12, 2013 at 6:31:28 AM
Page generation time: 0.3387
