54 Users Online (52 Members):
Forums >> Revit Structure >> Technical Support >> Visibility - Multi Layered Structural Tag
1 Posts No Rating |
I have created a structural tag that includes additional labels for user added information. However, this user added information may or may not always be required to be visible and I need to be able to turn each of the labels on or off as desired. I have built all the necessary parameters to do this including the necessary yes/no parameters for turning them off and on. However, I can not get these yes/no parameters to show up in my dialog box. If I am diagnosing the problem correctly, the problem stems from the fact that tags do not seem to allow for the use of shared parameters.
Does anyone know how I can make these yes/no parameters show up in my dialog box so that I can control which labels I want to use in my tag?
You will have to use different types that set these switches. Obviously, you will have to place the right tag for the specific view. Note that if you tag all in one view with tag one and adjust their place,ment, you can copy all and place same place in another view, then switch them all to tag two.
create-parts and multi-layered roofs with shape edits |
Sun, Feb 21, 2016 at 9:27:04 AM
Problem with Multi Category tag |
Mon, Apr 3, 2006 at 12:48:41 AM
Multi category tag in Revit 8. |
Mon, Mar 27, 2006 at 10:33:20 PM
Multi-Category Tag with horizontal leader lines - RAC 2012 |
Wed, Feb 15, 2012 at 4:29:14 PM
shared parameter in a structural framing tag? |
Fri, Jun 4, 2010 at 10:28:43 AM
