109 Users Online (108 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Workflow & Implementation >> Hardware >> Revit Benchmark
Fri, Nov 16, 2012 at 11:18:31 AM | Revit Benchmark
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
Hey guys I just wanted to share some Revit Architecture 2013 Benchmark scores that I got with a computer I built for under $1000 (its scoring better than the high power workstations that cost thousands)
RFO Benchmark v10.29.2012 (RAC 2013) run at 11/15/2012 6:01:03 PMRevitForum.org
Model creation and view export benchmark
7.00  opening and loading the custom template
11.00  creating the floors levels and grids
26.00  creating a group of walls and doors
43.00  modifying the group by adding a curtain wall
18.00  creating the exterior curtain wall
14.00  creating the sections
9.00  changing the curtain wall panel type
26.00  export all views as PNGs
35.00  export some views as DWGs
189.00  Total
Render benchmark
194.00  render
GPU benchmark*
17.00  refresh Hidden Line view - with hardware acceleration
12.00  refresh Consistent Colors view - with hardware acceleration
12.00  refresh Realistic view - with hardware acceleration
7.00  rotate view - with hardware acceleration
48.00  refresh Hidden Line view - without hardware acceleration
39.00  refresh Consistent Colors view - without hardware acceleration
38.00  refresh Realistic view - without hardware acceleration
32.00  rotate view - without hardware acceleration
* For Hardware Acceleration comparison only.  Do not use the GPU benchmark  for graphics card comparisons.
MACHINE SPEC:OS: Microsoft Windows 7 Ultimate  64-bit
CPU: AMD FX(tm)-8350 Eight-Core Processor
Max Clock Speed: 4.40 GHz
Number of Processors: 1Number of Logical Processors: 8
Total Physical Memory: 15.97 GB
A1_BANK0: 8.00 GB @ 800 MHz
A1_BANK2: 8.00 GB @ 800 MHz
Graphics Card: NVIDIA GeForce GTX 560 Ti  Graphics RAM: 1,024 MBDriver version: 9.18.13.697
Screen Resolution: 1920X1080Benchmark was run full screen
Edited on: Fri, Nov 16, 2012 at 11:21:24 AM
Fri, Nov 16, 2012 at 3:34:51 PM | Revit Benchmark
alabaster2513
3.5 Stars: 25 Votes
Comparison: My workstation at the office. HP Z620 ($2500)
RFO Benchmark v10.29.2012 (RAC 2013) run at 11/12/2012 11:01:05 AM
RevitForum.org
27.00  creating a group of walls and doors
46.00  modifying the group by adding a curtain wall
19.00  creating the exterior curtain wall
25.00  export all views as PNGs
38.00  export some views as DWGs
196.00  Total
Render benchmark
226.00  render
GPU benchmark*
11.00  refresh Consistent Colors view - with hardware acceleration
54.00  refresh Hidden Line view - without hardware acceleration
45.00  refresh Consistent Colors view - without hardware acceleration
42.00  refresh Realistic view - without hardware acceleration
30.00  rotate view - without hardware acceleration
MACHINE SPEC:OS: Microsoft Windows 7 Professional  64-bit
CPU: Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz
Max Clock Speed: 3.60 GHz
Total Physical Memory: 15.93 GB
CPU0: 4.00 GB @ 1600 MHz
Graphics Card: NVIDIA Quadro 600Graphics RAM: 1.00 GBDriver version: 8.17.12.7642
Screen Resolution: 1920X1200
Edited on: Fri, Nov 16, 2012 at 3:37:13 PM
Fri, Nov 30, 2012 at 1:41:27 PM | Revit Benchmark
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
Could you try overclocking the Intel to over 4.0-4.4Ghz?  Then maybe it would be a fair fight.
C'mon man, I would take a Quadro series card over a GeForce card anyday of the week.  I don't game though.
Basically the price descrepency here is an AMD chip vs. an overpriced Intel chip, right?  and a cheap GeForce card vs. the latest low end Nvidia Quadro card.  Take those two things and swap them, you bank about $850 (or more) in savings and you'd get a $1650 computer that runs faster than a $1050 computer.  That shouldn't be a surprise that a slightly more expensive computer is slightly better at its benchmarks.
If I'm not mistaken, your work computer is cheaper to operate due to lower power usage on both the Intel and Quadro chips....?
Either way, both have impressive benches, good work!
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Fri, Nov 30, 2012 at 2:27:24 PM | Revit Benchmark
alabaster2513
3.5 Stars: 25 Votes
I am unaware of any way you can overclock a Xeon processor, especially on a HP motherboard. My home build was on an $800 budget so I opted for the AMD platform. Another architect in my office built a similar budgeted PC with the i& and a step down on the gpu. his benchmarks are a little better. I've used quadros for years and am just unimpressed with them lately, my quadro 600 seems to do better in viewport rendering in 3ds Max but is pretty much useless for rendering with iray. My geforce on the otherhand performs slightly slower in viewport rendering but it screams with iray. I am new to overclocking but I am getting the clock speed slighty higher all the time on my AMD. Here is how my brain works: 3 people on custom built $800 machines vs 1 person working on a $2500 machine...
3>1
Fri, Nov 30, 2012 at 5:31:50 PM | Revit Benchmark
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
Does the iRay render actually turn out decent?  I have a pair of Quadro 4000's on my home machine and there is no better rendering out there for 15 seconds for a 1920x1080 rendering of a scene with 8 million polygons minimum.  I have got to believe that the new keplers will blow it out of the water once Autodesk finally gets them to work with iRay.  I be interested to see what a race between 4 - 560ti cards vs. 2 - Quadro 4000's would look like.  Got any benchmarks for that?  Looking to get the best bang for my buck since you can probably get 4 or 5 - 560's for the price of 2 - 4000's.
Edited on: Mon, Dec 3, 2012 at 10:04:21 AM
RB Cameron
Mon, Dec 3, 2012 at 10:49:36 AM | Revit Benchmark
alabaster2513
3.5 Stars: 25 Votes
there is a benchmark for iray on the area i believe. i just create a room with one light source and a ton of brass teapots and see how long it takes to do 1,000 iterations. iray is the simplest thing i've ever had to benchmark.
I hope the new iray is released soon, i just built my machine and wanted to test the 600 series geforces, they are even cheaper than the 500s. i think bang for the buck would be to build a system with a quadro 600 running your windows and add 3 geforce cards like a gtx 560 ti for cuda rendering. if money was not an issue id go with 3 teslas Smile
Mon, Dec 3, 2012 at 9:20:48 PM | Revit Benchmark
j0ker007
I couldnt get RFO Benchmark v10.29.2012 (RAC 2013) to work.  I keep hearing on the forums about file path but I have
installed on the c:\ and tired other folders
very odd but I just need a rendering benchmark so ill just use the RFO_Cornell-Box to test out speeds in my company.
Tue, Dec 4, 2012 at 11:17:30 AM | Revit Benchmark
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
Has anyone tried using a graphics card expansion box (PCI-e) like Netstor to directly tack on a second set of x16 connectors and add some CUDA cards to their system?  I'd like to take all the heat out of my tower that the cards make and push it to a secondary box.  Apparently no drivers are needed and the computer will automatically recognize the additional PCI-e cards thus iRay will recognize them.  Haven't tried it myself yet.  My worry is that you get a high end Nvidia card connect its PCIe-x16 slot into a "x16 but really a cut open x8" slot then connect it thru a x4 cable.  Not sure you'd lose any performance because that's still 20Gb/s worth of lanes of data it can push through.
RB Cameron
Tue, Dec 4, 2012 at 1:29:16 PM | Revit Benchmark
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
Or a Quadro Plex 7000?
Edited on: Tue, Dec 4, 2012 at 4:47:05 PM
RB Cameron
Tue, Dec 4, 2012 at 1:33:10 PM | Revit Benchmark
j0ker007
now are you guys talking about Ray trace / GPU rendering for Revit 2013?
Tue, Dec 4, 2012 at 4:49:16 PM | Revit Benchmark
#11
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
Sorry, Revit to 3dsMax for rendering in 3dsMax.  Although I'm interested to know if Revit uses GPU to do it's raytracing or is it all CPU based only?
RB Cameron
Tue, Dec 4, 2012 at 5:03:12 PM | Revit Benchmark
#12
alabaster2513
3.5 Stars: 25 Votes
web update 6 for 3ds max now has kepler support for iray
Wed, Dec 5, 2012 at 10:17:35 AM | Revit Benchmark
#13
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
Holy cow, this is a new era of rendering, thanks alabaster!
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20652715&linkID=9241178
RB Cameron
Wed, Dec 5, 2012 at 11:20:37 AM | Revit Benchmark
#14
alabaster2513
3.5 Stars: 25 Votes
now i get to go to frys and return the gtx 560 ti i just bought lol
Mon, Dec 17, 2012 at 10:47:40 AM | Revit Benchmark
#15
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
Hey alabaster,
I just got a PCIe expansion box (delivery sometime this month) and I'm going initially test a Quadro 600 I happen to have lying around.  So my computer will see 2- quadro 4000's and a quadro 600.  Question for you, have you had any experience mixing fermi and kepler cards on 3dsmax on the same system?  not a lot of google info out there on it.  my first inclination is just to slap in another quadro 4000 (256 cores and matching drivers) and play it safe...since those can be had for about the same price as a gtx 580 on ebay now.  but if i wanted to risk it, i'd dump in a 660ti.  Winking
thanks,
Edited on: Mon, Dec 17, 2012 at 10:49:14 AM
RB Cameron
benchmark survey - file size, project type & size
Thu, May 25, 2006 at 6:01:46 PM
Grid in 3d view
Sat, Aug 18, 2012 at 10:37:10 PM
Revit graphics card?
Thu, Feb 20, 2014 at 12:47:10 PM
Sheet Underlay
Fri, Sep 12, 2014 at 9:09:52 AM
Revit Architectural Classes in Matara SriLanka
Sat, Feb 16, 2019 at 8:49:07 PM
Page generation time: 3.3354
