13 Users Online (11 Members):
Forums >> Revit Systems >> Technical Support >> Revit 2013 - Can't Use Align Tool on Edge of Curtainwall
29 Posts No Rating |
Hi all,
New to the forum, but not Revit. I recently upgraded to 2013, and have found an issue that is driving me batty. Say I draw a curtainwall, and I wish to move it by Aligning one Edge with something. I select whatever reference edge, then try to click on my curtainwall to move it, but I cannot select the Edge! Tab-clicking does not work, as it used to. I can only select the centerline of the curtainwall. Anybody experienced this, have a solution? Thanks.
JP
That is correct. Align will only work with the CW location line. You can contol the CW by using a mullion.
Revit defaults to the center of mullions as their CW location. I believe in most cases, your mullions and panels should be set up on the exterior face. That is a better control point. If you don't choose to do that, you hav no choice but to use move instead of align.
Is this a change from 2012? It's been a few months since I used 2012, but I don't seem to remember this being a problem. Why would AutoDesk decrease their functionality?
No change - always been this way.
Curtainwall Ellipse |
Tue, Feb 21, 2006 at 10:40:26 PM
coneptual massing curtainwall mullion issue |
Thu, Nov 5, 2009 at 11:54:41 AM
Problem using 'paint tool' within copied groups - Revit 2013 |
Thu, May 23, 2013 at 6:36:47 AM
How do you make a canted or leaning curtainwall? |
Wed, Jul 21, 2010 at 8:07:26 PM
Aligning Face of Curtainwall w/ Face of Wall |
Tue, Mar 11, 2008 at 3:01:57 PM
