157 Users Online (156 Members):
Forums >> Revit Building >> Technical Support >> Detail from one file to another
I have drawn a detail in one file and want to make it possible to paste it into future projects, like a block in Autocad. It is only 2d. Can someone point me in the right direction or to a tutorial. Thanks, Puzzle.
Macca Sunshine Coast QLD Australia |
you will need to create it as a detail item (new family --> metric detal component) but you won't be able to copy from your project and paste into your new family.
what I would do (being the easiest way) is to export to dwg, than you can import your detail when ever you want.
anyone got a better way?
HTH
If the detail is just pure Revit drafting lines, then I would make a group out of those lines, rename the group something meaninful then export the group out of your project to a standard location as an .rvg file. (File>Save to Library>Save Group) In the future you can load the .rvg file into a new project and place into a drafting view. You could also pre-place the group into your template file if it occurs in every project of the same type.
If however you want to make a detail component that can be used to embelish model based details with a particular 2D component you created, then yes eldados is correct.
You could also use the group created from drafting lines in a model based detail as embelishment as well. The group for example could contain just the typical notes and leaders you use on a particular type of detail, or it could contain the 2D drafting lines, or combination there of.
HTH
Tom
Thanks for the replies. Appreciate the time taken.
Puzzle
problems loading detail components |
Mon, Jan 29, 2007 at 3:54:18 PM
Linked file model missing attached detail group |
Mon, Aug 17, 2009 at 8:26:38 AM
RA 2008:: Detail components out of place on 2d element insert from file |
Wed, Dec 22, 2010 at 3:30:17 PM
IFC detail drawing into Revit |
Mon, Nov 25, 2013 at 2:31:31 AM
Creating an Enlarged Detail View of a Detail I have Drawn |
Fri, Aug 31, 2012 at 7:05:29 AM
Members: | 1998589 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
