Forums >> Revit Systems >> Technical Support >> Export Model to AutoCAD - Layers, Pipe Types, Filters
Thu, Oct 11, 2012 at 2:18:26 PM | Export Model to AutoCAD - Layers, Pipe Types, Filters
koolair
4.5 Stars: 2 Votes
I am trying to export my model into AutoCAD, but need a way to regulate what layer my CHWS, CHWR, HWS, and HWR end up on.
Read this Wiki help for the background, in case the reader is not familiar:
http://wikihelp.autodesk.com/Revit/enu/Community/Tips_and_Tricks/Import%2c_Export%2c_Layers/Export_Pipes%2f%2f%2f%2fPipe_Fittings_to_different_DWG_Layers_basing_on_their_system
In step 4, it says "add System Name".
I don't name my pipes by system name or system type.  I've created duplicates of various different pipe types, always renaming them by CHWS or CHWR, etc...and also the same for fittings.  So in my VG, in filters, I create filters that pick up stuff by TYPE NAME.  I check off pipes, flex pipes, fittings, etc.
I want these pipes and ducts and etc etc to get exported into AutoCAD and retain their colors, pipe type name, line thickness, etc...
Anyone have any leads?
MEP AutoCAD Export issues
Sun, Mar 13, 2016 at 12:46:02 PM
Revit2012--->Autocad2012--->3DsMax2012
Wed, Jul 4, 2012 at 5:57:06 AM
Export fills to layers
Fri, Sep 11, 2009 at 11:51:47 PM
Lineweights For System Filters
Mon, Apr 20, 2015 at 2:28:08 PM
Pipe Accessories and Pipe Type parameter
Tue, Dec 27, 2011 at 11:25:39 AM
Page generation time: 2.3791
