Forums >> Revit Structure >> Technical Support >> Modelling a hollow core slab around a UC - Help Please.
Wed, Oct 10, 2012 at 5:26:22 AM | Modelling a hollow core slab around a UC - Help Please.
BlueFox1965
Hello,
This may be a daft question. I am trying to add a hollwcore beam layout on plan to a steel frame structure. When I choose the beam system method I am struggling to get the hollowcore units to "slot" around columns. The unit width is set @ 1200 and the last unit in each bay is set back a distance from the column web/ flange and encroaches on the next bay. Is the solution to draw the system and then remove the last unit, duplicate the original and change the dimensions to suit. Also my units don't apeaar to bear onto the beam flanges in the 3d model.
Any help advice much appreciated. Thanks in advance
regards Alan
Hollow Core Planks Modeled as Slabs Instead of Beams.
Mon, Feb 8, 2010 at 4:06:48 PM
Hollow Core Block Wall
Wed, Aug 13, 2008 at 7:53:37 PM
Trimming Precast-Hollow Core Slabs
Wed, Jun 3, 2009 at 10:52:21 AM
Custom slab modelling issues
Thu, Oct 29, 2009 at 7:25:09 AM
Core Slab and ICF
Tue, Apr 5, 2005 at 10:34:16 AM
Page generation time: 0.5788
