Forums >> Revit Structure >> Technical Support >> Create sloping top to structural column
Thu, Sep 27, 2012 at 3:00:17 AM | Create sloping top to structural column
windymiller
Can anyone explain how to go about creating a sloping top to a structural column please? 'Simples' I can hear you say!
Thu, Sep 27, 2012 at 3:22:59 AM | Create sloping top to structural column
4 Stars: 205 Votes
Simple.... goto a section/elevation view, create a "ref. plane" with the slope you want the CUT the column, use the "Cut Geometry" tool.
Fri, Sep 28, 2012 at 5:49:43 AM | Create sloping top to structural column
Alum
Should I add not to delete the ref plane after cutting?
Fri, Sep 28, 2012 at 6:00:29 AM | Create sloping top to structural column
4 Stars: 205 Votes
Why don't you try and tell us what happens? Shadey
Elevation at Top Parameter for Structural Column Schedule?
Mon, Nov 9, 2015 at 4:56:15 PM
Structural Column not working
Mon, Jul 2, 2018 at 10:20:09 AM
Revit newbie - Tapered circular column will not attach top/base properly
Thu, Aug 22, 2013 at 5:26:46 PM
How to extend top flange of beam (over top of column)?
Fri, Jun 15, 2012 at 10:35:08 AM
How do you align top of beam with top of column?
Wed, Feb 11, 2009 at 8:19:29 AM
Page generation time: 1.6546
