7 Users Online (5 Members):
Forums >> Revit Building >> Technical Support >> Double skin facade
4 Posts No Rating |
Hello there, I am trying to make a curtain wall with the layers glass/air/glass, with connections/bridges at three levels from the levels to the outer glass, a small section of glass on the outside should be frosted in front of the levels/floors/connections to hide what is behind. I have currently made a simple pattern with adjustable mullions, but there are nothing that holds the two layers together, and it's not even close to what I want to achieve..
The pattern wil be applied to a curved surface that is divided. Any ideas/suggestions/comments are very welcome.Here is my current pattern:http://d.pr/f/Yf3l
I hva attached google images of what I'm trying to approach.
If the wall is vertical DON'T USE a mass and wall by face.
I would just build this as two curtain walls and add your connecting elements as family elements placed separately.
Double Skin facade with folding shutters |
Tue, Nov 12, 2019 at 9:31:43 PM
Double-Skin Facade as a "Curtain System" on a "Mass". |
Sat, Nov 21, 2015 at 7:10:28 AM
Master Spec and Double Skin walls |
Wed, Dec 28, 2016 at 5:40:21 PM
Need assistants on double facade.... |
Tue, Feb 24, 2009 at 6:30:13 AM
Double layered honeycomb facade |
Thu, Apr 3, 2014 at 9:29:17 AM
