44 Users Online (42 Members):
Forums >> Revit Building >> Technical Support >> Revit Architecture 2012 - Can you create a stair with varying tread depths???
2 Posts No Rating |
Hi all
I have a building with an existing stair with two runs.
The lower run has a tread depth of 260mm and the upper run has a tread depth of 250mm.
Is it possible to create this in Revit Architecture 2012?
Thanks in advance for your help!
Emma
Create two stairs.
2 Posts No Rating |
Hi
Thanks for your response.
If I create two stairs, won't this affect scheduling and naming?
Thanks
Emma
I've never 'scheduled' stairs but yes the tagging would need a work around as in a dumb tag with a regular text label.
How to model a non-typical length stair tread for the top tread |
Mon, Jan 25, 2016 at 1:55:19 PM
Baluster per tread on curved stair |
Thu, Apr 4, 2013 at 2:18:52 PM
Stair Riser/Tread Number in Multistory Stairs |
Tue, Sep 13, 2016 at 9:47:54 AM
Custom Stair Tread Profile vs. Default Tread Profile |
Tue, Apr 30, 2019 at 2:28:08 PM
Precast concrete stair: notches and connections (Revit 2014) |
Thu, Jan 9, 2014 at 2:05:40 AM
