8 Users Online (6 Members):
Forums >> Revit Building >> Technical Support >> Underlay as dashed lines 2012
160 Posts No Rating |
I would like to show my ground floor walls as dashed lines.
I read a post by Mr Spot in the search from 2006 but could not follow it is it different in 2012? can anyon help. please.
I have a 2 level apartment block & want to show the ground floor walls as dashed so that I can design the floor framing easier but do not want the grey lines of the current underlay getting mixed up with floor framing details.
I will be scoring goals soon, I'm in the back line at the moment!
Cheers Dermot
www.dmbd.net |
I have found the answer. Go to the manage tab & to drop down addditional settings where you will find halftone/underlay, in that dialog there are 3 parameter you can change, Weight - Pattern & Brightness.
Cheers Dermot
www.dmbd.net |
2 Posts No Rating |
Excellent - exactly what I was searching for. Thanks for your help.
9 Posts No Rating |
you can always go to the Modify tab > go to view> click on the line work tool.
Highlight the lines you want to display differently and change the line type.
The idea was to change the underlay line style as a whole format rather than just single lines.
Cheers Dermot
www.dmbd.net |
How to show structure below dashed |
Tue, Jan 10, 2006 at 9:27:02 PM
11
Disappearing dashed lines? |
Tue, Feb 21, 2017 at 2:16:48 PM
Dashed lines in families are showing as solid lines in project |
Thu, May 10, 2012 at 8:38:48 AM
dashed lines above cut plane |
Fri, Jan 2, 2015 at 2:28:18 PM
Where is my underlay? |
Fri, Mar 20, 2009 at 11:43:15 AM
