Forums >> Revit Building >> Technical Support >> custom section tag woes
Tue, Jul 24, 2012 at 4:47:02 PM | custom section tag woes
sfountain
I made a custom section tag that only shows the detail number, which i use whenever i want to make a detail and place it on the same sheet the detail is called out from..works great except for one unexpected thing - should i need to refer to that detail, but from another sheet, revit overrides whatever section tag i choose at the time and uses my custom tag - not good since the custom tag has no sheet number on it.
Whats the deal here? shouldnt i be able to reference another detail and choose any section tag in the file?is it happening because ive modified the tag and did away with the sheet number? If i try to change the tag, revit changes all the tags associated with that detail.  other than faking the tag, can anyone suggest a workaround? i really dont want to give up that nice, small, detail number only tag!
 woops - using revit architecture 2012.
Edited on: Tue, Jul 24, 2012 at 4:52:02 PM
Custom Section Tag Rotating Lines
Tue, Jul 31, 2007 at 1:23:42 PM
Custom room Stamp/Tag in Revit
Sun, Oct 17, 2010 at 9:42:00 PM
Create & reference door tag parametrics
Thu, Nov 8, 2007 at 2:24:44 PM
adding arrow head to custom tags
Sat, Aug 3, 2013 at 9:49:15 PM
Section tag missing on plan but section still exists
Tue, Nov 22, 2016 at 2:58:15 PM
Page generation time: 3.0089
