Forums >> Revit Building >> Technical Support >> The finer points of the EQ constraint
Fri, Jul 13, 2012 at 1:35:29 PM | The finer points of the EQ constraint
NMODIE
Arright folks, this one is driving me @#$%'ing nuts. I'm sure it's a simple problem, but alas.
When I dimension several items, and then go to click the EQ icon, how do I determine what moves?
For example: Let's say I'm putting a few windows on a building and I want them to be equally distributed across the facade with respect to the other walls, pretty standard scenario. I dimension them up, then hit the EQ guy, and the walls all want to move half the time. Is there a clicking order that I haven't picked up on? Why doesn't it matter whether or not I've pinned those walls? I wouldn't have pinned them unless I didn't want them to move! Of course I don't want to remove the constraints!!! [blows stack, steam and curses everywhere] !!!
Your assistance would be greatly appreciated,
Cheers,
Noah
Fri, Jul 13, 2012 at 2:10:21 PM | The finer points of the EQ constraint
No clicking order.
If you have constrained correctly by a (A-only 1) pin or a (A - only 1) dimension then the other items will move in realtion to the constrained item.
Did you know that deleting a locked dimension does not release the lock?
Did you know that a locked dimension in any view is a lock everwhere - it is a model?
To release hidden (or deleted) dimension locks, add a new dimension - lock it - then unlock it.
constraints not satisfied... driving me crazy
Thu, Nov 7, 2013 at 9:47:06 AM
Topographic points
Thu, Nov 27, 2008 at 9:22:44 PM
Keep getting constraint error in "Nested & Arrayed Families by: Mr. Spot" tutori
Wed, Dec 8, 2004 at 3:13:13 PM
Revit Cant Find Reference Planes in Mullion Profile
Fri, Aug 28, 2015 at 1:09:47 PM
Door Sidelight Constraint
Mon, Apr 24, 2006 at 12:56:28 AM
Page generation time: 0.0590
