Forums >> Revit Building >> Technical Support >> Generic Connection
Thu, Jul 5, 2012 at 8:05:14 AM | Generic Connection
matatmicad
Afternoon all.
We are using Revit 2012 and attempting to set up some families for a company.  What I want to do is basically have separate components of a Man hole that will connect to either concrete pipework component families or a concrete ring to complete the manhole above. Basically I want to create 'lego' type families which will just snap to a connector rather then a face or workplane.
Is there any other way of doing this then using a systems connector as these attempt to create pipework or ductwork in my project even if I put in a fittings or global connector type.
The end product I would like is to basically insert a component that will have 2 points that will easily snap to each other on each family.
I have been using generic family templates.
Alternative to a VPN connection for worksharing - Faster remote connection
Tue, Oct 12, 2010 at 8:51:02 AM
2011 conduit connection
Thu, Jun 10, 2010 at 1:15:54 PM
Precast stair with notch connection
Fri, Aug 26, 2016 at 1:05:15 AM
MISSING MOMENT FILLED CONNECTION
Wed, Apr 4, 2012 at 9:34:26 AM
The connection between wall and floor
Fri, May 14, 2010 at 8:43:26 AM
Page generation time: 0.0705
