61 Users Online (59 Members):
Forums >> Revit Building >> Technical Support >> library part constraints not shown
I opened a sidelite because its trim doesn like to be adjusted. and I want to redraw all the trim and fix it, but all the dimension parameters are hidden or something. But I know they are there because I get the warnings about breaking constrains...how do I make it all visible. the light bulb is grayed out too.
VG....Turn them on
some are already on. so its not a VG problem. it seems like the dims were deleted with the constraints remaining.
Ah... That could be ... or they could be constraints on a sketch? If they were deleted, you can always add new - lock then unlock.
I think awhile back I remember something where you could remove all constraints ... or that could have been a wish?
OH MAN that would be cool. at least while messing with families.
Setting Default Wall Constraints |
Fri, Jan 5, 2007 at 2:45:05 PM
lines of library part not same when in project |
Mon, Nov 24, 2014 at 7:42:58 AM
Problems with constraints (Doors and iron mongrey) |
Fri, Oct 24, 2008 at 6:14:54 AM
Constraints Are Not Satisfied when opening file - Revit Architecture 2008 |
Wed, Aug 27, 2008 at 9:46:30 AM
Library Management Tools |
Thu, Feb 7, 2008 at 3:18:56 PM
