Forums >> Revit Systems >> Technical Support >> export to gbxml
Tue, Jun 12, 2012 at 2:26:11 PM | export to gbxml
vinnygolfer
4.5 Stars: 4 Votes
hi, i'm using Revit 2013. i was given an older Architecture model and opened it up. i placed the spaces in the model and renamed them. then i tried to export to a gbxml file to be used for analysis. i get an error message that there are no rooms in the model. why would i need to have rooms, if i have the spaces? i realize that when i was created, it was in Revit Architecture and not the new combined program. but i don't know why i would have to make rooms and spaces in the same place.
Try to learn at least one new thing every day
Wed, Jun 13, 2012 at 11:15:09 AM | export to gbxml
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Rooms are RAC elements and Spaces are MEP elements. In the past Spaces were generated from the Rooms.
Not sure why the gbxml wants the model to include Rooms when it has Spaces ? Could be a glitch in the new 'combined' software?
Mon, Aug 27, 2012 at 6:14:20 AM | export to gbxml
Davidmorg
Hi Vinny,
In the "export gbxml - settings" dialogue box change the export category from rooms to spaces.
I am having a problem when trying to import the GBXML from REVIT 2013 into Ecotect.
I get this message:
"WARNING: IFC support is only at beta stage in this release. Whilst detailed geometry should import, ifcSpace data and complex curves may not transform correctly"
And it does import nothing (0 spaces, 0 surfaces, 0 ...)
Does anyone know what the problem is? and How can this be solved?
I never had any problems when importing gbxml that were obtained from Revit2012.
Mon, Aug 27, 2012 at 6:33:21 AM | export to gbxml
vinnygolfer
4.5 Stars: 4 Votes
thank you David that worked. i've never even opened Ecotect, sorry i can't be of any help with that.
Mon, Aug 27, 2012 at 6:44:25 AM | export to gbxml
Davidmorg
No problem Vinny.
The additional thing that I asked about Ecotect can be taken as just a warning that maybe GBXMLs exported from Revit 2013 are not performing as they did previously.
Thu, Aug 30, 2012 at 9:48:37 AM | export to gbxml
Davidmorg
The solution to my problem.
autodesk.typepad.com/bimtoolbox/2012/08/...to-ecotect-2011.html
How to include links in a GBXML export
Thu, Sep 25, 2008 at 9:35:00 AM
Problem in dwg file import Revit then export gbXML file
Sat, Sep 1, 2012 at 8:57:09 PM
GBXML Export - Rooms V Analytical Surfaces
Wed, May 19, 2010 at 10:08:40 PM
Exporting gbxml
Wed, Nov 14, 2007 at 2:35:39 PM
about gbXML
Tue, Oct 7, 2008 at 5:44:12 PM
Page generation time: 0.0978
