560 Users Online (8 Members): Show Users Online - Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM
Forums >> Workflow & Implementation >> Training >> wall by face
Fri, Jun 1, 2012 at 2:48:32 PM | wall by face
viktorik
Hi to all , here is my another problem wit some joined masses, wall by face igmore the joins, it shows the correct face but the wall is applied to all height, I tried to divide the face, but that resolved only some faces nat all, I tried to make cuts into that big mass, and nothing better, the wall ignors tha little joined, or cuted mass,
may be there is a better way or place where I can modelo multy joined,cuted masses, where I can get that masses for base...
(sorry for my bad english)
thanks!
Fri, Jun 1, 2012 at 3:02:51 PM | wall by face
viktorik
same with that mass, first time it have done very well, but after some manipulations here, and added new masses, it doesn't want to apply correct any more, neighbor faces are working well... don't remember when it disappeared ...
Fri, Jun 1, 2012 at 3:03:55 PM | wall by face
3.5 Stars: 405 Votes
You have to build the mass with a hole where the join is.
I would build most of this with regular walls - much easier and then other components work right.
Edited on: Fri, Jun 1, 2012 at 3:06:13 PM
Sat, Jun 2, 2012 at 3:23:33 AM | wall by face
viktorik
But how to cut the windows-curtain in a regular wall, there are angles at intersection ,  the mass for curtain isn't perpendicular to the face for a wall by face,
Sat, Jun 2, 2012 at 3:32:16 AM | wall by face
viktorik
And somewhere I need 2 kinds of walls, with different material only, like here ...
Sat, Jun 2, 2012 at 6:38:54 AM | viktorik
4 Stars: 206 Votes
Quoting viktorik from 2012-06-02 03:23:33
But how to cut the windows-curtain in a regular wall, there are angles at intersection ,  the mass for curtain isn't perpendicular to the face for a wall by face, "
Use IN-PLACE VOIDS in Wall category.
Sat, Jun 2, 2012 at 11:16:36 AM | wall by face
viktorik
I am beginner sorry, I can't find it,  here I have wall opening in architecture tab, near is shaft , opening by face...
Sat, Jun 2, 2012 at 11:52:03 AM | wall by face
viktorik
component>model in place>>void extrusion>cut> ?   only thing that I don't see the void in view after appliing the in place model. wall is cutted but the void have no control arrow , is it so?  not bad for my situation it cuttaed at all, and all multiple walls, thanks ...
Sat, Jun 2, 2012 at 2:47:58 PM | wall by face
viktorik
and if I delete the wall , where I can find that in-place void? , when wall was the in place void wa selectable from the aparent edges ...
thanks to all , problems mostly resolved...
Sun, Jun 3, 2012 at 3:55:33 AM | wall by face
4 Stars: 206 Votes
"component>model in place>>void extrusion>cut> ?" - Yes
"and if I delete the wall , where I can find that in-place void?" - If you create a void to cut a wall then you delete that wall, the void is erased because it wont have anything to cut.
Wed, Sep 19, 2012 at 12:25:50 AM | wall by face
#11
IoanIancu
2.5 Stars: 2 Votes
You have to use the Curtain System tool on the Massing tab of the Design Bar. Mel Persin, AIA AEC Technology Consultant Technology to Visualize and Realize Solutions Modeling for the Future/Drafting in the Present/Building on the Pas.....
scrapbooking
Thu, Sep 5, 2013 at 7:43:59 AM | WWHub
#12
samjohnsonus
3 Stars: 2 Votes
Quoting WWHub from 2012-06-01 15:03:55
Edited on: Fri, Jun 1, 2012 at 3:06:13 PM"
WWHub: Thanks for the solution
Why can't you upgrade your file to 2009? - I DID!
Wed, May 28, 2008 at 5:03:21 PM
Architectural Working Drawings and As built models in Revit
Sat, Aug 30, 2008 at 6:20:42 AM
Architectural documentation support services using Revit
Thu, Feb 19, 2009 at 6:11:40 PM
Create.NewFamilyInstance isn't displaying a new family on sheet
Mon, May 9, 2011 at 1:06:22 PM
Anyone else having crash problems with 2010?
Mon, Jun 22, 2009 at 12:51:48 PM
Page generation time: 0.5536
