7 Users Online (5 Members):
Forums >> Revit Building >> Technical Support >> How to reset your stand-alone Autodesk product licenses
Issue:
Your stand-alone Autodesk product licenses have become corrupted and you want to know how they can be reset.
Solution:
Use the following steps to reset the stand-alone licenses for all Autodesk products (version 2010 or higher):
1. Make sure there is no Autodesk product currently running. If there is, close the application.
2. Rename the adskflex_00691b00_tsf.data file to adskflex_00691b00_tsf.data.old. This file can be found at the following locations:
Windows XP
C:\Documents and Settings\All Users\Application Data\FLEXnet\
Vista/Windows 7
C:\ProgramData\FLEXnet\
3. Restart your Autodesk product and go through the activation procedure again.
Note: This file contains all product activations for all 2010 and higher Autodesk products installed on your system. You will need to re-register these products if this file is renamed/deleted.
Original post: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15890817&linkID=9240617&CMP=OTC-RSSSUP01
Edited on: Sun, May 27, 2012 at 6:40:50 AM
Revir Subscriptions |
Thu, May 26, 2016 at 2:55:37 AM
RAC 2008 Freeze after Pressing Register while Activate Product. |
Tue, Mar 25, 2008 at 2:49:03 AM
Use 'License Tranfer Utility' for Temporary, Telecommuting Revit Drafters? |
Tue, Apr 20, 2010 at 10:28:38 AM
Some computers can't find a license |
Fri, Aug 19, 2016 at 7:17:14 AM
Work From Home With Revit |
Fri, May 14, 2010 at 8:20:11 PM
