Forums >> Revit Building >> Technical Support >> custom hatch pattern
Mon, May 21, 2012 at 4:03:51 PM | custom hatch pattern
SteveB
3.5 Stars: 5 Votes
I have created this pattern: an 8" spaced hexagon of continuous lines
*HEXSB, Hexagons;%TYPE=MODEL-120,0,0,9.25,0120,4.625,0,9.25,00,0,0,0,8
I have saved it as Revit-SB.pat
when I try to load it into with fill pattern / new / custom / import   i get the message "no model type patterns found"
the numbers come from the chart attached.  What am I doing wrong???  syntax???
Mon, May 21, 2012 at 4:07:53 PM | custom hatch pattern
SteveB
3.5 Stars: 5 Votes
that chart came out wrong, see the attached .pat file:
Mon, May 21, 2012 at 4:14:49 PM | custom hatch pattern
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Looks like the hatch pats I remember.  is the semicolon before the %type necessary?  i can't remember off the top of my head.
consider getting the Mertens3D "hatch22" plug-in.  It's free.  You draw your hatch with revit lines, and then it converts it to hatch pattern file for you.  I've been told this might not be backward-compatible in a cad export sense, but I can testify it works GREAT within revit.  I've made a half dozen or so custom wood textures that blow all of our old CAD pats out of the water.
Edit:  didn't see your revised post.
Edited on: Mon, May 21, 2012 at 4:17:03 PM
Mon, May 21, 2012 at 4:15:56 PM | custom hatch pattern
SteveB
3.5 Stars: 5 Votes
see the 2nd post, with the attached .pat file.  I did that, it just cut/pasted wrong in the 1st post.
Mon, May 21, 2012 at 4:33:00 PM | custom hatch pattern
itsmyalterego
4 Stars: 16 Votes
just made this in hatch 22.
As you can see, it's not elegant, but then again, none of us are using 486 DOS boxes that care about 800byte pats vs 5kb pats.
Tue, May 22, 2012 at 6:03:56 AM | custom hatch pattern
SteveB
3.5 Stars: 5 Votes
Thanks!   That Mertens add-in looks to be really clever.  They say the r2013 version is pending.  I installed on r2012 and couldn't quite figure out how to work it, but I definitely will re-visit it.  You pattern worked like a charm.
Tue, May 22, 2012 at 6:23:41 AM | custom hatch pattern
SteveB
3.5 Stars: 5 Votes
OK, I took a couple minutes to figure it out, it works like a charm.  Hats off to Mertens!  Do you know of a place that keeps track of available add-ins and 3rd party Revit products?
Thu, May 31, 2012 at 12:47:50 PM | custom hatch pattern
mertens3d
5 Stars: 2 Votes
I posted a new version of hatch22-2012 last night. It is now compatible with 2013.
There is also a revit file with a bunch of sample hatch patterns and the templates used to create them.
...gregory
http://mertens3d.com
my Revit - Bugs/ Issues/ Requests
Thu, May 31, 2012 at 2:59:11 PM | custom hatch pattern
SteveB
3.5 Stars: 5 Votes
thanks gregory.  Thats a clever marketing tool.
Is there a listing somewhere of revit plug ins available?
Thu, May 31, 2012 at 3:25:25 PM | custom hatch pattern
mertens3d
5 Stars: 2 Votes
YW Steve.
There are a couple sites out there that i've come across, but I haven't bookmarked any.
I'll bet someone on here will have some links.
...gregory
Fri, Jun 22, 2012 at 5:59:09 PM | custom hatch pattern
shehab10
Thanks
mertens3d
you make me love converting from archicad to revit because making hatch pattern in archicad was easy but with your good free tool i am happy thanks.
custom hatch pattern without hatch editor
Wed, Jan 28, 2015 at 8:46:58 PM
hatch pattern not printing
Mon, May 8, 2017 at 12:56:51 PM
Hatch pattern
Tue, Jan 13, 2009 at 10:23:47 AM
Mon, Jul 6, 2009 at 12:18:03 PM
Custom Hatch Patterns on Revit [ 1 2 ]
Fri, Jul 31, 2020 at 1:39:38 PM
16
Page generation time: 1.3361
