Forums >> Revit Systems >> Technical Support >> How can I edit the text for the elevation (level) marker?
Thu, Apr 26, 2012 at 2:43:36 PM | How can I edit the text for the elevation (level) marker?
kgcaddesign
They are showing up as Arial and I want to change it to Stylus BT, how can I change them? Thank you.
Thu, Apr 26, 2012 at 3:37:28 PM | How can I edit the text for the elevation (level) marker?
Edit the family then edit the label type.
Split a an elevation marker up for mulitple sheets
Tue, Oct 4, 2016 at 2:29:34 PM
Elevation Level Marker Associated To Wrong Floor Plan
Wed, Feb 25, 2015 at 10:44:23 AM
Level Marks???
Wed, Apr 8, 2015 at 2:06:31 PM
Text Orientation in Custom Elevation Marker
Fri, May 6, 2011 at 10:36:12 AM
Adding a reference elevation to an existing elevation marker?
Wed, Sep 17, 2014 at 7:57:46 AM
Page generation time: 0.6438
