Forums >> Revit Building >> Technical Support >> Revit 2013
Fri, Apr 6, 2012 at 2:30:57 PM | Revit 2013
SteveB
3.5 Stars: 5 Votes
I've been using Autodesk products since release 1 in 1985 (I remember a breathless instructor saying "it can make an ARRAY!", then watching it draw an auditorium layout of 2-d chairs one at a time for a couple minutes).  So I was eager to jump into revit 2013.  Nice new display options "realistic" and "raytrace" and "sky" image background.  But as noted in their release readme, the "sky" images background should only be used to make a rendering, it is unstable.  I get lots of crashes in r2013, I am going to try to un-check the "sky" background.   Also it takes a very long time to load and convert from r2012 files:  seems like 15 to 20 minutes on 1st load.  My desktop has lots of ram and processor speed, wouldn't think that can't be it.  r2013 seems to semi-freeze up if you walk away from it for a while, then start working again, and other unexpected lags/freezes which seem like "saves" but aren't:  these feel like what earlier releases used to do if you didn't turn off the shadow display mode.
Very nice new parametric stairs feature.
Fri, Apr 6, 2012 at 4:13:56 PM | Revit 2013
revitape
revitape Avatar
4.5 Stars: 9 Votes
Thanks for posting your input. I personally haven't dl'ed yet but I will be on the lookout for the issues/features you mentioned.
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture
Sat, Apr 7, 2012 at 4:48:02 AM | Revit 2013
4 Stars: 205 Votes
Here: http://www.revitcity.com/forums.php?action=viewthread&thread_id=27088
Sat, Apr 7, 2012 at 9:36:14 AM | Typhoon
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting Typhoon from 2012-04-07 04:48:02
Wow, based on this seems like production people should wait for the next build.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
REVIT 2013 Materials Library Video Tutorial
Tue, May 28, 2013 at 5:12:56 AM
13
Problem with Revit 2013 Not Responding
Thu, Oct 10, 2013 at 12:25:28 PM
11
"auto" open in Revit 2012, when you have both 2012 and 2013
Sun, Jul 12, 2015 at 4:52:17 PM
WorksetExplorer for Revit 2013
Wed, Mar 20, 2013 at 9:48:16 AM
Upgrading Revit 2010 project to Revit 2013
Wed, May 23, 2012 at 1:28:20 PM
Page generation time: 1.8985
