487 Users Online (33 Members): Show Users Online - Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM
Forums >> Community >> Newbies >> Aaargh can't figure out those site settings!!
Thu, Mar 15, 2012 at 9:22:46 PM | Aaargh can't figure out those site settings!!
JoBrowns
I've created a toposurface which is 22' high, a piece of irregular land with 2 sides that are sharply sloped. Basically I want to have contours every 5' from 0 to 19' and then from 19' to 22' have contours every 1'. I have tried to set that in the site settings, but it keeps showing 1' contours from bottom to top!!What am I doing wrong?Your help is appreciated.Joseph
Fri, Mar 16, 2012 at 7:48:26 AM | Aaargh can't figure out those site settings!!
Change your site settings.  Massing and site tab / model site pull down arrow / at intervals of.....
Fri, Mar 16, 2012 at 8:18:59 AM | Aaargh can't figure out those site settings!!
JoBrowns
That is exactly what I did. If you look at the 2 pics below, the first 1 is the contour lines. The steep slope (with contour lines very close together) at the top and right are up to 19' from the base. This is the part I wanted to make the contour lines 5' apart. Look at the second pic. It's the site settings - which i did. The site settings as seen here, the first line of site settings, although I indicated 5' contour lines, still gives me lines 1' apart up to 19' (as seen in picture #1).There's something amiss here.
Fri, Mar 16, 2012 at 9:12:36 AM | Aaargh can't figure out those site settings!!
Sorry - forgot to tell you to adjust the other settings instead if you use those.  So in your case, change the secondary contour spacings.  (Or - Turn those off in VG settings in the view?)
Fri, Mar 16, 2012 at 10:04:37 AM | Aaargh can't figure out those site settings!!
JoBrowns
sorry you are unclear when you say "So in your case, change the secondary contour spacings.  (Or - Turn those off in VG settings in the view?)" if you look at my site settings, what is there to turn off? From 0 to 19 is 5' and from 19 to 30 is 1' so what do I turn off?
many thanks
Fri, Mar 16, 2012 at 10:18:33 AM | Aaargh can't figure out those site settings!!
CDWdavid
5 Stars: 5 Votes
Hi JoBrowns, personally, I do not recommend to show the contour lines in different intervals, which might lead to misread the slope of the site. You may change the line weights to show much thinner lines for 1' contour lines.
Hoping that you can find your solution.
Fri, Mar 16, 2012 at 10:20:53 AM | Aaargh can't figure out those site settings!!
Sorry - I had not correctly read your original post.  I had simply read that you wanted 5' spacing instead of 1' .   I have never tried this.
It appears that the start/stop setting for secondary contours does not function correctly.  I suggest you send this to AutoDESK.
I spend many time for printing
Thu, Oct 5, 2006 at 4:23:41 PM
May Contest || Program Info
Tue, Jul 18, 2006 at 10:17:25 AM
Help! Edit Family
Wed, Nov 30, 2005 at 11:41:21 PM
Philosophical Rant about Revit
Thu, Jun 1, 2006 at 9:47:05 PM
Issues with Linked View
Fri, Apr 5, 2013 at 12:53:32 PM
Page generation time: 1.4500
