Forums >> Revit Building >> Technical Support >> Anti Climb Railing Modelling
Tue, Mar 13, 2012 at 11:27:05 AM | Anti Climb Railing Modelling
MEBDesign
Hi Guys,
Another quick question. Trying to model some anti climb railings. Ie. railings where the top handrail is set forward to the lower railings. I'm very much a beginner at this but to do this I made a custom profile balustrade and then offset the various railings so that they fitted the new profile. My first problem was that the design requires corner posts so I then modelled another balustrade at a 45degree angle to use at the corners however this is only works propely on the external corners, the internal corners are angled the wrong direction - anything I can do to correct this?
Second problem is that dispite going through all the settings I cant seem to get the balustrades spaced nicely between the corner posts. What settings should I be using?
I've attached an image to help.
Many Thanks
Simon
Tue, Mar 13, 2012 at 11:48:09 AM | Anti Climb Railing Modelling
MEBDesign
Revit 2012 by the way
Tue, Mar 13, 2012 at 12:12:57 PM | Anti Climb Railing Modelling
Remember, you can have more than one railing in the same place and you can also have separate families.  So your rails could be one railing.  And your posts might be several separate railing segments that give you the proper post spacings.  You might have to place the corner posts as independent elements.
Railing not shown in list
Mon, Jun 30, 2014 at 4:25:56 PM
rectangular railing
Mon, Nov 26, 2012 at 7:30:07 AM
Railing Turns Into Transparent Red
Thu, Aug 10, 2017 at 2:06:41 AM
Railing and Baluster Profiles not inserting on centerline?
Fri, Oct 5, 2012 at 2:26:20 PM
Anti-aliased Revit/WIndows interface?
Tue, May 22, 2007 at 1:27:45 PM
13
Page generation time: 2.9315
