455 Users Online (34 Members): Show Users Online - Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM
Forums >> Revit Building >> Technical Support >> model pattern size
Sat, Mar 10, 2012 at 7:15:55 PM | model pattern size
spacey
I wanted to create a surface pattern to represent panel joints on cladding, but found that the maximum extent of a pattern was smaller than the 3m panel size.
Is there a way around this?
Sun, Mar 11, 2012 at 11:33:11 PM | model pattern size
hugh
3.5 Stars: 4 Votes
That is true of DRAFTING patterns, but I suspect you should be creating a MODEL pattern which can handle much larger patterns:
http://hatchkit.com.au/faq_detail.php?id=7
Put a ine containing
;%TYPE=MODEL
at the start of the pattern definiition as explained here:
http://revitmotion.blogspot.com.au/2010/05/custom-pattern-files.html
Hugh Adamson
www.hatchkit.com.au
Mon, Mar 12, 2012 at 12:37:14 AM | model pattern size
spacey
Thanks for that!
It was a Model pattern, but after a closer look at the file, I discovered I had no units defined in the file.
When I added ;%UNITS=MM  all worked fine.
I am guessing it defaults to inches or feet if not defined, and this led to the size error.
Mon, Mar 12, 2012 at 6:53:46 AM | model pattern size
hugh
3.5 Stars: 4 Votes
Glad you spotted that. Defaults to DRAFTING and INCHES for some reason Smile
Those with patterns expressed in feet or metres can scale up by 12 or 1000 as appropriate on loading.
Hugh Adamson
www.hatchkit.com.au
Create.NewFamilyInstance isn't displaying a new family on sheet
Mon, May 9, 2011 at 1:06:22 PM
Modelling terrain Revit imported from AutoCad
Thu, Oct 20, 2011 at 9:29:49 AM
Why can't you upgrade your file to 2009? - I DID!
Sat, Nov 8, 2008 at 10:10:30 PM
PROBLEM WITH IDENTIFY A ENVIRONMENTS
Mon, May 28, 2012 at 5:16:30 PM
New to revit and have a few questions
Wed, Jul 22, 2009 at 10:08:27 AM
Page generation time: 0.5300
