60 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Model Lines not showing up
Wed, Feb 29, 2012 at 1:01:36 PM | Model Lines not showing up
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I have a project where I am using model lines to represent machines in a floor plan.  When I draw the model lines they disappear right away.  I have checked my VV/VG and everything is turned on.  I can drag my cursor across the screen and still select them but I cannot see them, I can however see detail lines.  What am I missing?
Revit Architecture 2012
Edited on: Wed, Feb 29, 2012 at 1:02:50 PM
Wed, Feb 29, 2012 at 1:04:20 PM | Model Lines not showing up
What is your workplane setting?  Is you floor top higher than your work plane (level)?
Edited on: Wed, Feb 29, 2012 at 1:04:54 PM
Wed, Feb 29, 2012 at 1:10:12 PM | Model Lines not showing up
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I got them to show up.  I have a site plan that is linked into my model and for some reason it was covering up my model lines. Thanks a lot!
Ceiling Model Lines Showing up on Floor Plan
Tue, Dec 13, 2011 at 6:04:04 AM
Model lines not showing up on slab surface
Sun, May 1, 2016 at 8:30:20 AM
Can you convert model lines to detail lines?
Wed, Mar 31, 2010 at 12:45:23 PM
Dashed lines in families are showing as solid lines in project
Thu, May 10, 2012 at 8:38:48 AM
Linked model reference lines showing
Fri, Feb 10, 2012 at 9:28:59 AM
Page generation time: 8.0379
