61 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Edit Wall Profile & Room Bounding = FAIL
Tue, Feb 14, 2012 at 2:11:24 PM | Edit Wall Profile & Room Bounding = FAIL RAC2012
mybimhero
I have a 3 story building with floor to floor heights of 12.5' The peak of the roof is at 50' and slopes down to 25 on both ends. The shell walls are tilt up concrete and run trhough the building so at times they act as internal walls as well as the shell. They are set to 60' high and we have edited the profile of the shell walls to follow the slope with a 4' parapet. The ends and the bottom remain as is.
Once those profiles were edited, rooms PASS THROUGH the shell wall!! The walls are all set to "bound room". The room heights are all 8' . To make matters worse, this is random. It does NOT occur on the first and 2nd floor but does occur on the 3rd floor. There are no openings in the wall either. When I "resaet profile", the rooms are all bound correctly. When I edit the profile again - they pass through the wall.
I have found 1 or 2 posts regarding this issue back in 2005. I would think that Autodesk has resolved something as simple as this. If I put room seperation lines down - then I get warnings of walls and rs lines overlapping. I have noticed that if I make the edit higher up (which we dont want) it still contains the room. Once I get below a certan threshold, it craps out. The rooms are bound by the walls at al times so this is perplexing. Any ideas? Thanks!!
Edited on: Tue, Feb 14, 2012 at 6:11:54 PM
RAC 2012
room bounding problem
Fri, Jul 28, 2017 at 4:03:50 AM
13
room bounding parameter in wall
Fri, Jun 27, 2008 at 10:17:07 AM
Room bounding...
Sat, Jan 6, 2007 at 7:39:42 PM
BIG curtain wall room bounding problem!!
Mon, Dec 14, 2009 at 9:31:31 AM
Curtain Wall & Room Bounding Dissapeared
Mon, Jun 27, 2011 at 9:36:36 AM
Page generation time: 5.1504
