31 Users Online (29 Members):
Forums >> Revit Building >> Technical Support >> Another Roof Issue..
Hey guys I'm doing an extension. The existing 2 gables were at the same height but now I am making one bigger so the
roof of the existing gabel will need to be built up to tie in. It nearly did it but no quite. Any ideas?
http://screencast.com/t/ICsqPX8rsd
http://screencast.com/t/Pp9RAvoWYd
Revit 2018........ |
any takers.....
hi jamie,
two ways to do this that i can think of.
1) do it as 1 roof and just note on elevations extent of new, if phasing etc not an issue. this was easiest and quickest.
2) do as 3 roofs. 1st roof existing gable end, 2nd roof new gable end with valley and hip lines drawn in (without slope) as it overlaps existing 1st roof, and then the third roof being a triangular section to close off hip end of 2nd gable roof.
to get things aligned use side elevation, select triangular roof and move up to ridge of first existing roof.
hope all that make sense.
regards
mansell
ohh legend. Thanks heaps man 3 roofs worked awesome. Thanks again mate.
http://screencast.com/t/Nhad1Kyt1foO
Roof Joining Issue |
Fri, Jan 4, 2013 at 2:37:38 PM
Roof by Face on curved mass surface issue |
Mon, Oct 5, 2015 at 12:39:58 AM
Roof Issue |
Sat, Sep 12, 2020 at 2:09:42 PM
11
Linestyle Display Issue |
Tue, Jan 25, 2011 at 8:57:09 AM
Additional Roof will not attach to original roof |
Fri, Jun 7, 2013 at 7:56:40 AM
