5 Users Online (3 Members):
Forums >> Revit Building >> Technical Support >> Nested Families
16 Posts No Rating |
Is it possible to Tag a Nested Family, and it's Host Family separate with two different equipment tags, and have both tags show up separately in a schedule? For example, Can I insert a family with 2 nested families into a project, then apply three tags with three different values and have it schedule that way?
Sure ... the nested family has to be set to shared.
From your HELP:
shared family
A family of model elements that can be used to create subcomponents of a nested family.
When you use shared families to create a nested family, you can select, tag, and schedule the individual subcomponents in a project. (If subcomponents are not from shared families, Revit Architecture treats an instance of the nested family as a single item for selecting, tagging, and scheduling.)
See also nested family. For more information, see The Families Guide."
23 Posts No Rating |
Can I bump this one?
Here's what I've got. I have a family that has two nested families in it. I don't want the nested families to show in my schedule. So what I did was - Edit the family, then edit the nested family. Change it from Shared to Not Shared and load it back into the family it is nested in. I got the message "Can't load family because a shared version already exists." How can I get it nto shared without deleting and reloading/rebuilding the family?
In the host family, edit the name of the nested family. Now it will load.
Thank you WWhub, that worked great!!!
Locking nested families? |
Wed, Aug 27, 2008 at 12:23:09 PM
13
nested families do not cut |
Thu, Jan 14, 2010 at 11:44:55 AM
Door swings with nested families |
Fri, Sep 18, 2009 at 1:41:24 PM
Hiding nested families in a project |
Thu, Jan 14, 2010 at 10:21:37 AM
turning on/off nested families in host family in different views in project. |
Fri, Aug 7, 2009 at 11:11:32 AM
