11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Help with creating a glazed exterior curtainwall with radial mullions
3 Posts No Rating |
I am new to revit and have been teaching myself how to do everything so far. I am working on modeling a building for my company and I have reached a roadblock. I am trying to create an arched exterior glass glazing with mullions on different radials. I also am trying to figure out how to do the slop on the facade of the building.
The attached jpg is the best way for me to explain what i am attempting.
you are not going to be able to use the traditional curtainwall functions to create that. i suggest using the conceptual massing tools or perhaps the family editor.
I would do all of the vertical, horizontal and perimeter mullions using the curtainwall. One large panel in the upper area. Then add an in-place family for the radial mullions.
3 Posts No Rating |
Thank you both for your suggestions!
I have the elevation of this as a dwg file. is there any way I am able to import that in and draw from that? Perhaps transform it into a inplace family?
You could place your curtainwall, then in elevation, import your elevation so you could locate your mullions.
Yes, you could also use this import to create an in-place family.
NOTE: My advice above is only for the flat, vertical planes. I looked again at your image and the sloped glazing areas will probably have to be seperate modeled in place elements.
Different sized Mullions |
Wed, Aug 7, 2019 at 5:48:08 AM
Creating a vertical continuous mullion with a profile edited curtainwall |
Tue, Mar 22, 2016 at 10:46:17 AM
Clean embedded curtainwall corners |
Fri, Oct 7, 2016 at 11:33:31 AM
offset curtain wall grid? |
Mon, Jan 28, 2008 at 7:35:30 AM
Adding mullions to curtain walls |
Thu, Jan 27, 2011 at 12:08:52 PM
