Forums >> Workflow & Implementation >> Training >> Designing irregular stairs
Mon, Jan 9, 2012 at 1:35:58 PM | Designing irregular stairs
kelava
How would I go about designing stairs that don't have a straight path?
Example: stairs that curve to one side while going up.
I have tried several ways and was unsuccesfull.
Mon, Jan 9, 2012 at 1:53:59 PM | Designing irregular stairs
Just sketch it the way you want it.
See image from your HELP...
Mon, Jan 9, 2012 at 1:57:38 PM | Designing irregular stairs
kelava
I have... but it didn't work... not sure what the problem could be.
Tue, Jan 10, 2012 at 11:23:42 AM | Designing irregular stairs
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
read your help
Tue, Jan 10, 2012 at 12:57:33 PM | Designing irregular stairs
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Here's a few quick tips.
Make sure you 'split' the boundary lines where ever it goes from flat to sloping.
Riser lines must start and end on a boundary line.
You can only have two boundary lines and they cannot touch each other.
None of the linework can cross each other. Just intersect.
HELP WITH STAIRS
Thu, May 25, 2006 at 10:00:41 AM
Irregular Ceiling
Mon, Aug 4, 2008 at 1:45:52 AM
Trying to create stairs
Mon, Mar 30, 2009 at 8:42:03 PM
irregular patterned stucco wall
Tue, Jan 27, 2009 at 9:03:41 AM
how to make an irregular slope surface
Fri, Apr 1, 2011 at 10:12:27 PM
Page generation time: 0.7055
