Forums >> Revit Systems >> Technical Support >> Solid Works to Revit
Tue, Dec 20, 2011 at 3:28:46 AM | Solid Works to Revit
abauer4242
I have dental chairs and units in solid works I am trying to get into Revit. I've tried SolidWorks save file to step AP214, open in Inventor Fusion, save to SAT and open in Revit. No great success. Miscolanious things dissapear and you can not add materials to render. turns into grey lumps. Trying to rebuild the units in Revit but as a moddeling software Revit is not working. Complex forms are not working.
Any ideas how I can get this to work with rendering and no holes everywhere?
Tue, Dec 20, 2011 at 10:47:44 AM | Solid Works to Revit
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
have you tried, sketchup. then import them into a family, then import to revit.
Wed, Dec 21, 2011 at 1:39:51 AM | Solid Works to Revit
abauer4242
I haven't used Sketch up before and was trying to get this done without have to learn another software. Is sketch up good for complex forms?
Wed, Dec 21, 2011 at 11:00:50 AM | Solid Works to Revit
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
I believe you can save your solid works files to something that can be read in Sketchup, then you can save them in a format, that can be read by Revit. And yes sketch up is pretty good with unusual forms, also check out 3D warehouse. Some manufacturer's are using sketchup for there 3D modeling for use in Revit and other 3D programs.
Edited on: Wed, Dec 21, 2011 at 11:03:20 AM
create floor or other solid mass from Topo
Wed, Oct 2, 2013 at 9:29:26 PM
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:01 PM
X, Y, Z SOLID EXTRUSION
Wed, Jan 5, 2011 at 12:02:16 PM
Revit and solid state hard drives
Mon, Feb 2, 2009 at 9:31:28 AM
Solid Sweep Not Cutting in Section
Mon, Dec 18, 2006 at 2:06:34 PM
Page generation time: 2.3373
