Forums >> Revit Systems >> Technical Support >> EXCEL LINKING REVIT MEP 2012
Tue, Nov 1, 2011 at 6:39:06 AM | EXCEL LINKING REVIT MEP 2012
Agile3100
Has anyone come up with a way to link and excel file to Revit yet? Making an image is out of the question with how many panelboards we show and way too time consuming. Any ideas are appreciated!
Tue, Nov 1, 2011 at 9:02:51 AM | EXCEL LINKING REVIT MEP 2012
There is no excel linking in Revit yet.  You schould be able to schedule your panelboards in Revit.
Mon, Nov 14, 2011 at 12:09:45 AM | EXCEL LINKING REVIT MEP 2012
ralf007
a work around is to link it into autocad then link the autocad drawing into revit it works fine
every time the excel is updated you have to open and reload the excel in autocad, then save, then hit reload in the manage tool with revit to update it.
Fri, Dec 9, 2011 at 12:18:24 PM | EXCEL LINKING REVIT MEP 2012
Agile3100
Can you tell me how you link this into CAD please? Because everytime I link my CAD dwg into Revit I get an ActiveX error suggesting that I explode the excel file or change my proxygraphics to 1, which it already was. I am linking the excel file by paste special. This is the second time that I have seen this suggestion but i have never been able to get it to work.
Wed, Dec 14, 2011 at 11:30:16 PM | EXCEL LINKING REVIT MEP 2012
ralf007
depending on what version of autocad your using
you want to datalink the excel file,
under insert on the ribbon there linking and extraction, or with the command "datalink" after that there a few easy steps to get it loaded into autocad
hope that helps
Thu, Dec 15, 2011 at 9:39:42 AM | EXCEL LINKING REVIT MEP 2012
Agile3100
That worked! We were using paste special and linking them that way. Thankyou
Wed, Dec 28, 2011 at 2:54:06 PM | EXCEL LINKING REVIT MEP 2012
MacRowerGT
MacRowerGT Avatar
2 Stars: 2 Votes
Using Excel 2010I created all of my schedules in one Excel Spreadsheet.  Each Schedule and legend on a different worksheet. I formatted all text to Arial 12.save this within your project folder.
AutoCAD 20121. Create a New File name it the schedule title2. Home > Table  choose From a data link. Select Launch the Data Link Manager dialog3. Create a new data link,  Name the Link the schedule title.4. Browse for your excel path, full path, select the worksheet and I use the link to range as I can control what fields are imported.5. OK6. OK7, Arrange your tables in CAD as you will want them to appear on your sheet.  It's helpful to create a faux viewport in CAD to help you.  ONce complete you can delete it.8. SAVE FILE
Revit 20121. Open your sheet and select Insert > inke CAD2. Choose you saved DWG file3. Position and SAVE
Done!Now when you update the Excel File, You'll need to update links in the CAD file then you can use Manage Links in Revit to Reload the DWG.
Utilizing Revit Building Suite 2014
Wed, Dec 28, 2011 at 3:06:20 PM | EXCEL LINKING REVIT MEP 2012
mhans
3 Stars: 10 Votes
Just a word of caution. I find in the past that linking Excel to Autotcad was unstable. Now with your link to Revit from Autocad with Excel file that's something really dangerous, especially with a panelboard schedule. I like WWHub to just do your schedule in Revit. Unless you are not really BIMing your world. I guess, Revit has a valid point (somehow) in not linking a common .xls file into it. Smile
Motto: "No Post left behind"
EXCEL LINKING!
Mon, May 8, 2006 at 8:19:56 AM
Linking Revit files to Excel
Wed, Jan 22, 2014 at 3:30:36 PM
12
REVIT MEP - Separate models for MEP disciplines
Tue, Jun 25, 2013 at 1:45:42 PM
Why can't Revit and Excel just be friends
Mon, Dec 21, 2009 at 10:17:40 AM
Import/Linking Excel Sheets into Electrical Components
Wed, May 20, 2009 at 9:45:53 AM
Page generation time: 1.2907
