38 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Placing Doors - Constraints
Tue, Nov 1, 2011 at 6:15:54 AM | Placing Doors - Constraints
Jezza2k3
I'm working on a project in which all wall lengths are modularised to block dimensions of 225mm. Obviously the widths of the door opes within these walls will also use the same modular dimension.  Is there a process by which I can apply constraints to a door family, so that when placed, the dimension from the door to the nearest adjacent wall always assumes a multiple of 225mm?
I'd appreciate your help.
Cheers!
Tue, Nov 1, 2011 at 6:56:04 AM | Placing Doors - Constraints
Sorry but you can't do this.  You do have temporary dimensions when you place the door and you can adjust it then.
Problems with constraints (Doors and iron mongrey)
Fri, Oct 24, 2008 at 6:14:54 AM
Setting Default Wall Constraints
Fri, Jan 5, 2007 at 2:45:05 PM
Placing doors/windows at midpoints of walls??
Tue, Jan 25, 2005 at 5:44:52 PM
45 degree door swing for Double Doors
Wed, Apr 11, 2007 at 9:56:41 AM
Creating Family/Placing doors and windows
Mon, Apr 9, 2018 at 10:09:40 AM
Page generation time: 5.4694
