72 Users Online (71 Members):
Forums >> Revit Building >> Technical Support >> Please Help: Seeing wireframe pieces in a hidden line elevation
8 Posts No Rating |
Just noticed one of my sections is doing this same thing. Not all of the sections however....
3 Posts No Rating |
I have been having the same issue. I have discovered that issue arrises when the wall profile has been edited. This happens in all my elevation.
I have tried everything from
- No view Template
- Creating A reference plane for the wall top to be hosted with the same result
- Creating new elevation
The Only solution I have found to work is creating a Mass then creating a wall by face however this does make it hard to manipulate when changes are required.
8 Posts No Rating |
Prelude,
It turns out that I had a CAD file imported somewhere WAY off into space. It makes absolutely no sense, but this can cause your walls in elevations and sections to be transparent. It turns out it was really a pretty simple fix. Here is what I did: 1.) Went to default 3D view. 2.) Zoomed to Extents. 3.) Selected All. 4.) Opened Filter Tool. 5.) Checked "none". 6.) Found an imported CAD file in the list, checked the box next to it, and deleted it.
Thanks!
8 Posts No Rating |
By the Way WWhub, thanks for all of your help.
In my case this problem was related to the imported dwg file as well. If you go to the Visibilty/graphics overrides, then choose imported categories, uncheck visibility for all imported layers and things return to normal.
1 Posts No Rating |
Check to see what the DETAIL LEVEL of the elevation having an issue.
If the detail level is set to MEDIUM or HIGH, change it to COARSE.
Hidden Line View [ 1 2 ] |
Wed, Oct 6, 2010 at 2:49:02 AM
22
"hidden Line" Visual style becomes wireframe with CAD file |
Mon, Feb 28, 2022 at 3:04:02 AM
11
Hidden Line . . .? not for me |
Tue, Jul 19, 2011 at 3:41:04 PM
RAC 2012 - Structural Section View shows as Wireframe vs. Hidden Line |
Wed, Mar 7, 2012 at 1:50:31 PM
Wireframe lines showing up in Shaded 3D View |
Thu, Apr 2, 2009 at 11:36:35 AM
Members: | 1996349 | Objects: | 22885 | Forum Posts: | 152178 | Job Listings: | 3 |
