490 Users Online (55 Members):
- Most ever was 3914 - Wed, Aug 26, 2026 at 4:53:14 AM |
Forums >> Revit Structure >> Technical Support >> Framing Plan problem with displaying
I think I might have messed up and would like someone to help me out of this mess.
I have a sloping roof with a high bmd el and a lo bmd el. I drew such on the elevation, they are 5' apart. Anyway, when I did this it created two plans. Well being new to Revit I drew joists and beams on both plans - the high beams on the high plan and the low ones on the low plan, and the joists that are sloping from low to high I put on the low plan. Anyway now looking at it I would like all the joists and beams to be on one plan, so I only have one roof framing plan not two. How can I get these to combine, I tried the view range thing and it will show the low plan joists and beams but it will not show the sizes. Other than staring over with the framing I don't know what to do.
(As you can see - I am new to revit!)
Yeesh - Where is My Cad
Yeesh - Where is My Cad |
I don't use structures but this sounds like a hosting issue. You should be able to click on the elements not showing their sizes and re-host them to your new level. You will probably then have to change their location based on that level.
That is not working - what I want to do is take the two plans and combine them into one. So I have beams called off on both plans. It is modeled right on the elevations and on the 3d but plan wise it is all wrong. I would like to know how to fix this just incase in the future I need to combine plans.
Sloped framing and framing plans |
Tue, Apr 11, 2006 at 7:47:26 PM
Creating 2D Framing Plans |
Tue, Oct 21, 2008 at 8:38:59 AM
Stone Veneer and Framing Plan |
Wed, Nov 14, 2007 at 12:12:22 PM
Floor plan is missing in view |
Fri, Nov 4, 2016 at 10:03:46 AM
Wood Framing Walls Extension; Locating and External framing |
Fri, Jul 31, 2015 at 8:03:14 PM
Members: | 2181668 | Objects: | 23399 | Forum Posts: | 152360 | Job Listings: | 0 |
