Forums >> Revit Building >> Technical Support >> Revit 2012 Inquiry
Thu, Oct 13, 2011 at 8:46:11 AM | Revit 2012 Inquiry
tmassey
tmassey Avatar
I noticed within the manage inquiry warnings that projects are running in excess of 30-50 errors. items such as Wall Joins unconnected, Multiple instances, Floor slopes, identical instances etc.
This should not be? Correct?
Using Revit Architecture 2012
Thu, Oct 13, 2011 at 9:12:39 AM | Revit 2012 Inquiry
That number may be OK but you should fix the bad errors such as multiples in the same place.
Thu, Oct 13, 2011 at 1:10:22 PM | Revit 2012 Inquiry
tmassey
tmassey Avatar
Thank you
Distance Inquiry In Imperial On Metric Project
Fri, Aug 8, 2014 at 9:05:58 AM
SF Inquiry tool like in Acad??
Wed, Jul 23, 2008 at 8:40:47 AM
Inquiry tools Like Acad??
Thu, Jul 24, 2008 at 1:26:29 PM
"auto" open in Revit 2012, when you have both 2012 and 2013
Sun, Jul 12, 2015 at 4:52:17 PM
Revit 2012 crashes at splash screen HELP!!!
Fri, May 17, 2013 at 1:13:24 PM
Page generation time: 5.5373
