16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Stairs problem
Hey guys,
Having a problem with stairs. I want to do a rectangle stair case which travels up 3 levels i want one over the top of the
other but obviously it will be higher. Revit says its overlapping but it doesnt understand that it will be at a different level
also can i specify what level i want my landings at?
http://screencast.com/t/FWIaU4HL9i
when i try to overlap it kind of works i get this
http://screencast.com/t/dXlzvTVdGt
Edited on: Thu, Sep 29, 2011 at 8:08:06 PM
Revit 2018........ |
There was a thread on this yesterday with an interesting workaround.
Typically, NO, you cannot have overlapping boundary lines. it gets confused. But... apparently if you draw your stair as a spiral... finish it, and then edit it and drag the sketch lines to overlap it is able to remember that it's not a crisscross of overlapping boundaries.
I'm not sure I'd recommend this, still. It'll be a pain in the curse to edit, later. I'd build it in three separate stages, one per floor.
Here: http://www.revitcity.com/forums.php?action=viewthread&thread_id=8494
Stairs Issue - Fliping problem |
Wed, Nov 1, 2017 at 3:51:49 PM
Problem with U-shaped stairs |
Tue, Jul 9, 2013 at 8:10:56 AM
My railings doesn't go with my stairs |
Mon, Dec 2, 2013 at 11:45:03 AM
14
Grand stair problem revit 2014 |
Thu, Jun 15, 2017 at 11:19:46 AM
problem with stairs and ramp?HELP |
Sun, Jun 1, 2008 at 11:49:57 PM
