15 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Sheet family - FIXED objects
90 Posts No Rating |
How can I FIX some objects on the sheet?
Here is a screen shot:
http://screencast.com/t/OPpzTLg2xdwc
The TEXT is fixed and does not move around when I change the family type but the boxes around it keep moving.
Do you wanna SKYPE Revit? Its quicker  |
Can't tell from your post what your question is.
Something to consider. I think most users build simple, multiple families for their sheets rather than complicated families like this. Although "all in one" families are possible, they are hard to build and maintain and they often result in larger project files.
The problem is that when I change the type of sheet, the frames around the text disapear.
I would like to learn more about multi-type families, specially on sheets Any good tutorial you know of?
Thanks
Start with what AutoDESK provides. Download the Families Guide from the AutoDESK site.
objects in view on sheet set not showing up in PDF |
Wed, Jul 10, 2013 at 7:00:02 AM
Hidden Objects in Sheet views |
Fri, Jun 13, 2008 at 12:10:26 PM
Revit Sheet Schedule/Title Block Family Tie In |
Mon, Jun 23, 2014 at 9:47:21 AM
EQ Dimensions and Fixed Distances |
Wed, Nov 27, 2013 at 1:26:36 PM
How to fixed error when uploading family to project rvt. file |
Tue, Jun 19, 2012 at 4:16:04 PM
